楼主: 李家老九
[求助] NX11.0刚刚发现的问题,路过的给看看
3 G币 回复本帖可获得 3 G币奖励! 每人限 1 次
发表于 2016-8-14 13:02:47 | 显示全部楼层
Use the Use Level Based option to create the IPW which is a representation of uncut regions of the part. The Use Level Based option is available for Cavity Mill, Plunge Milling, and Rest Milling operations. The Level Based IPW uses 2D cut regions from previous operations that are referenced to identify the remaining stock.
Note
The Use Level Based IPW option is for corners and stair-steps on walls. This option does not consider blank material left behind by adjacent passes within a cut level pattern. Scallops within the cut-regions are ignored and considered fully removed.
You cannot view the Level Based IPW.
nx11的原文帮助文件
发表于 2016-8-14 13:30:15 | 显示全部楼层
回帖奖励 +3 G币
964648756 发表于 2016-8-14 13:02
Use the Use Level Based option to create the IPW which is a representation of uncut regions of the p ...
说了这么多是什么意思呢
发表于 2016-8-14 13:31:02 | 显示全部楼层
看来没有用11.0还是挺明智的哦
发表于 2016-8-14 13:34:19 | 显示全部楼层
刚才又用8.5版本的测试了一下,基于层没有问题,11.0的的确有这个问题,大家可以看看以前版本的帮助文件有没有刚才This option does not consider blank material left behind by adjacent passes within a cut level pattern. Scallops within the cut-regions are ignored and considered fully removed.这句话
发表于 2016-8-14 13:36:51 | 显示全部楼层
回帖奖励 +3 G币
下载两次,文件都损坏了,照着画了 一个,没有发现问题
发表于 2016-8-14 13:51:47 | 显示全部楼层
一粗
一粗
二粗
二粗
发表于 2016-8-14 13:53:56 | 显示全部楼层
解决办法就是不要用这个命令,用这个命令代替
点评
”ignore“这个开关有问题,不用为好  发表于 2016-8-14 14:42
这办法好,赞一个  发表于 2016-8-14 14:40
发表于 2016-8-14 13:56:33 | 显示全部楼层
文件上传看看啊
发表于 2016-8-14 14:04:07 | 显示全部楼层
回帖奖励 +3 G币
11编程更换刀具还会变转速吗
131
中将
发表于 2016-8-14 14:20:57 | 显示全部楼层
回帖奖励 +3 G币
實體薄體混雜算刀路少不了你撞刀,恭禧你又得一隻銑刀頭。
GMT+8, 2025-9-13 11:31
