查看: 10285|回复: 13
[视频教程] UG NX11.0全新表达式工具使用视频演示【Siemens_PLM官方】
站长优秀版主论坛技术员论坛元老论坛贡献推广达人
发表于 2016-7-20 09:52:26 | 显示全部楼层 |阅读模式
Expressions are a versatile way to control model parameters in your design, and now you have more customization options and increased usability with the newly redesigned expressions system in NX 11.
You will notice improvements in three key areas:
  • Entering expressions
  • Changing expressions
  • Sorting expressions
Entering expressions is fast and streamlined with the new enhancements you get in NX 11. A spreadsheet-like format allows you to enter values in cells or copy and paste directly from Microsoft Excel. When you begin to type a string, NX anticipates your intent and automatically fills in the value for you.
Additionally, dimensions and units update automatically with the default setting. So, say you have parameters for both time and distance; now you want to create speed. Once you enter the formula distance/time, the dimensionality automatically changes to velocity and the units change to mm/sec.
Finally, a big pain point for users in the past came from errors. Error checking in NX 11 eliminates this problem; now when you attempt to create a parameter that already exists, you get an error message. Error checking prevents you from doing things that aren’t allowed by the system.
Changing expressions is easier for you in NX 11 as well. You simply click on a cell to edit it, and you can even edit multiple expressions at one time. Any expressions that reference the one you changed will update automatically to reflect the new value. You will also notice that now when you change an expression, two colors appear: Dark orange indicates changed expressions and light orange indicates any affected expressions.
NX 11 also gives you added controls for sorting expressions to help you maintain readability and usability for downstream use. Advanced filtering allows you to sort columns by any number of options: Name, formula, value, expression type, source, comment, and feature type. Filter visible expressions by groups to show only the active ones you’re currently working on, for example. This level of customization makes it easier to work with.
Thanks for watching.
Scott
发表于 2016-7-20 10:03:29 | 显示全部楼层
顶一个
爱好者终身VIP
发表于 2016-7-20 11:04:17 | 显示全部楼层
搶到沙發嚕!! 針開新  可是內容文章有看沒懂
40
发表于 2016-7-20 19:12:45 | 显示全部楼层
相互学习,共同进步!~
发表于 2016-7-20 19:38:05 | 显示全部楼层
{:biggrin:}这个要好好学习一下
发表于 2016-7-20 20:32:32 | 显示全部楼层
唉,文化程度有限啊。
灌水王论坛元老
发表于 2016-7-20 22:14:50 | 显示全部楼层
路過,學習學習!!!
发表于 2016-7-21 00:22:22 | 显示全部楼层
来涨涨知识,
发表于 2016-7-28 17:33:15 | 显示全部楼层
看不懂!!
发表于 2016-8-4 16:04:19 | 显示全部楼层
纯英文 看不懂啊……
GMT+8, 2026-9-28 08:07
