查看: 2171|回复: 2
[求助] powermill4轴转360度抬刀问题
发表于 2016-6-16 12:34:15 | 显示全部楼层 |阅读模式
  spindle elevation rotation = false
  elevation axis units       = degrees
  elevation axis direction   = positive
  spline type                = none
  workplane angles           = none
  option file units          = none
  maximum feedrate           =  9999.0000
  minimum feedrate           =     1.0000
  rapid feedrate             =  9999.0000
  maximum tape length        =     0.0000
  plunge threshold angle     =     0.0000
  maximum segment            =     0.0000
  diameter                   =     1.0000
  withdrawal amount          =    50.0000
  arc radius limit           = 10000.0000
  retraction threshhold angle  = 360.0000
  arc minimum radius         =     0.0000
  elevation centre           = ( 0.0 0.0 0.0 )
  elevation axis param       = ( 0.0 0.0 0.0  1.0 0.0 0.0 )
  pcs origin                 = ( 0.0 0.0 0.0  0.0 0.0 0.0 )
  linear axis limits         = ( -9999.0 9999.0 -9999.0 9999.0 -9999.0 9999.0 )
  rotary axis limits         = (  -0.0  0.0  -360.0  360.0  0.05 1 )
  initial tool vector            = ( 0 0 1 )
  retract at angular limit       = true
  unwind at tool change          = false
  multiaxis coordinate transform = true
  linearise multiaxis moves      = false
  withdrawal amount              = 100.0
  integer 3                      = 1
 楼主| 发表于 2016-6-16 12:35:36 | 显示全部楼层
Z34.991 A-349.853
Z34.987 A-355.378
Z34.98 A-360.
Z134.98 F9999
A0.0
Z38.98
Z34.98 F500
Z34.996 A-.638 F1000
X10.002 Z34.997 A-5.423
 楼主| 发表于 2016-6-16 12:37:02 | 显示全部楼层
不想有抬刀,连续加工,机床A轴设置为路径最短
GMT+8, 2025-4-2 16:52
