查看: 4755|回复: 5
[求助] NX10.0升级后帮助文档奇怪的打不开了
发表于 2016-4-21 15:04:22 | 显示全部楼层 |阅读模式
下面是错误日志,烦请各位大人帮忙看看是什么原因,多谢了!!!
HTTP ERROR 500
Problem accessing /tdoc/nx/10/nx_help/. Reason:
    Server Error
Caused by:
org.apache.jasper.JasperException: PWC6033: Error in Javac compilation for JSP
PWC6199: Generated servlet error:
The type java.io.ObjectInputStream cannot be resolved. It is indirectly referenced from required .class files
        at org.apache.jasper.compiler.DefaultErrorHandler.javacError(DefaultErrorHandler.java:129)
        at org.apache.jasper.compiler.ErrorDispatcher.javacError(ErrorDispatcher.java:299)
        at org.apache.jasper.compiler.Compiler.generateClass(Compiler.java:392)
        at org.apache.jasper.compiler.Compiler.compile(Compiler.java:453)
        at org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:625)
        at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:374)
        at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:492)
        at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:378)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
        at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:669)
        at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1448)
        at org.apache.logging.log4j.core.web.Log4jServletFilter.doFilter(Log4jServletFilter.java:59)
        at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1419)
        at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:455)
        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:137)
        at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:575)
        at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)
        at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1075)
        at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:384)
        at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:193)
        at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1009)
        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:135)
        at org.eclipse.jetty.server.Dispatcher.forward(Dispatcher.java:276)
        at org.eclipse.jetty.server.Dispatcher.forward(Dispatcher.java:103)
        at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:209)
        at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:267)
        at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1221)
        at org.springframework.web.servlet.DispatcherServlet.processDispatchResult(DispatcherServlet.java:1005)
        at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:952)
        at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:870)
        at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:961)
        at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:852)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:735)
        at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:837)
        at org.apache.logging.log4j.core.web.Log4jServletFilter.doFilter(Log4jServletFilter.java:66)
 楼主| 发表于 2016-4-21 17:09:45 | 显示全部楼层
酱爆 发表于 2016-4-21 15:48
UG10.0帮助文档无法使用的重要原因(比如:不能显示帮助信息500错误、无法显示此页)
http://www.ugsnx.co ...
已经解决了,是java更新造成的,这个错误报告上显示的就是跟java有关的,我把现在的java卸载后把原来的装上并禁止更新就ok了
357
发表于 2016-4-21 15:48:56 | 显示全部楼层
回帖奖励 +1 G币
http://www.ugsnx.com/thread-41462-1-1.html
(出处: UG爱好者)
 楼主| 发表于 2016-4-21 16:51:56 | 显示全部楼层
可是我的情况跟他的不一样,吧里的我几乎都看过了
 楼主| 发表于 2016-4-21 17:10:11 | 显示全部楼层
 楼主| 发表于 2016-4-21 17:12:15 | 显示全部楼层
问题已经解决!这个情况是由于java更新造成的,把现版本的java卸载后重新安装原来nx10.0安装包里的破解java就ok了
GMT+8, 2025-2-6 03:06
