查看: 7296|回复: 8
[求助] UG8.0怎么能用输出r时也执行螺旋下刀及螺旋铣孔功能
发表于 2016-3-4 23:02:31 | 显示全部楼层 |阅读模式
nx8后处理,处理螺旋铣孔和螺旋下刀时报警,在三菱m70系统上铣圆弧用ijk时报警,但改为输出为r时螺旋时不执行。请教高手怎么能用输出r时也执行螺旋下刀及螺旋铣孔功能。
 楼主| 发表于 2016-3-4 23:03:06 | 显示全部楼层
O0003
G40 G17 G49 G80 G90 G21
G91 G28 Z0.0
T05 M06
(XD8)
G00 G90 G54 X13.3 Y-.15 S2000 M03
G43 Z-15. H05
G03 X12.575 Y-.875 R.725 F250.
X13.3 Y-1.6 R.725
X13.3 Y-1.6 Z-15.16 R1.45
X13.3 Y-1.6 Z-15.32 R1.45
X13.3 Y-1.6 Z-15.48 R1.45
X13.3 Y-1.6 Z-15.64 R1.45
X13.3 Y-1.6 Z-15.8 R1.45
X13.3 Y-1.6 Z-15.96 R1.45
X13.3 Y-1.6 Z-16.12 R1.45
X13.3 Y-1.6 Z-16.28 R1.45
X13.3 Y-1.6 Z-16.44 R1.45
X13.3 Y-1.6 Z-16.6 R1.45
X13.3 Y-1.6 Z-16.76 R1.45
X13.3 Y-1.6 Z-16.92 R1.45
X13.3 Y-1.6 Z-17.08 R1.45
X13.3 Y-1.6 Z-17.24 R1.45
X13.3 Y-1.6 Z-17.4 R1.45
X13.3 Y-1.6 Z-17.56 R1.45
X13.3 Y-1.6 Z-17.72 R1.45
X13.3 Y-1.6 Z-17.88 R1.45
X13.3 Y-1.6 Z-18.04 R1.45
X13.3 Y-1.6 Z-18.2 R1.45
X13.3 Y-1.6 Z-18.36 R1.45
X13.3 Y-1.6 Z-18.52 R1.45
X13.3 Y-1.6 Z-18.68 R1.45
X13.3 Y-1.6 Z-18.84 R1.45
X13.3 Y-1.6 Z-19. R1.45
X13.3 Y-1.6 Z-19.16 R1.45
X13.3 Y-1.6 Z-19.32 R1.45
X13.3 Y-1.6 Z-19.48 R1.45
X13.3 Y-1.6 Z-19.64 R1.45
X13.3 Y-1.6 Z-19.8 R1.45
X13.3 Y-1.6 Z-19.96 R1.45
X13.3 Y-1.6 Z-20.12 R1.45
X13.3 Y-1.6 Z-20.28 R1.45
X13.3 Y-1.6 Z-20.44 R1.45
X13.3 Y-1.6 Z-20.6 R1.45
X13.3 Y-1.6 Z-20.76 R1.45
X13.3 Y-1.6 Z-20.92 R1.45
X13.3 Y-1.6 Z-21.08 R1.45
X13.3 Y-1.6 Z-21.24 R1.45
X13.3 Y-1.6 Z-21.4 R1.45
X13.3 Y-1.6 Z-21.56 R1.45
X13.3 Y-1.6 Z-21.72 R1.45
X13.3 Y-1.6 Z-21.88 R1.45
X13.3 Y-1.6 Z-22.04 R1.45
X13.3 Y-1.6 Z-22.2 R1.45
X13.3 Y-1.6 Z-22.36 R1.45
X13.3 Y-1.6 Z-22.52 R1.45
X13.3 Y-1.6 Z-22.68 R1.45
X13.3 Y-1.6 Z-22.84 R1.45
X13.3 Y-1.6 Z-23. R1.45
X13.3 Y-1.6 Z-23.16 R1.45
X13.3 Y-1.6 Z-23.32 R1.45
X13.3 Y-1.6 Z-23.48 R1.45
X13.3 Y-1.6 Z-23.64 R1.45
X13.3 Y-1.6 Z-23.8 R1.45
X13.3 Y-1.6 Z-23.96 R1.45
X13.3 Y-1.6 Z-24.12 R1.45
X13.3 Y-1.6 Z-24.28 R1.45
X13.3 Y-1.6 Z-24.44 R1.45
X13.3 Y-1.6 Z-24.6 R1.45
X13.3 Y-1.6 Z-24.76 R1.45
X13.3 Y-1.6 Z-24.92 R1.45
X13.3 Y-1.6 Z-25.08 R1.45
X13.3 Y-1.6 Z-25.24 R1.45
X13.3 Y-1.6 Z-25.4 R1.45
X13.3 Y-1.6 Z-25.56 R1.45
X13.3 Y-1.6 Z-25.72 R1.45
X13.3 Y-1.6 Z-25.88 R1.45
X13.3 Y-1.6 Z-26.04 R1.45
X13.3 Y-1.6 Z-26.2 R1.45
X13.3 Y-1.6 Z-26.36 R1.45
X12.275 Y-1.175 Z-26.5 R1.45
X13.3 Y-1.6 R1.45
X14.75 Y-.15 R1.45
X13.3 Y1.3 R1.45
X11.85 Y-.15 R1.45
X12.275 Y-1.175 R1.45
X12.787 Y-1.388 R.725
X13.512 Y-.663 R.725
X13.3 Y-.15 R.725
M05
M09
G00 Z100.
G91 G28 Z0.0
G91 G28 Y0.0
M30
 楼主| 发表于 2016-3-4 23:23:51 | 显示全部楼层
报警信息
WARNING: SMALL ARC ; ABORTED TO LINEAR MOVE
MOM_first_turret
MOM_turret_change
发表于 2016-3-5 02:19:58 | 显示全部楼层
R不能走全圆,在后处理去掉K值,或者用宏程序,要编程螺旋铣加工
 楼主| 发表于 2016-3-15 21:52:09 | 显示全部楼层
谢谢解答,你好,我想问一下后处理去掉k不是没z向倾斜了吗{:smile:}
发表于 2016-4-1 12:37:37 | 显示全部楼层
根据系统的不同,可以分类处理,有的机床的K值会报警,有的机床则不会,这个是由参数设置而达到
发表于 2016-4-12 12:46:46 | 显示全部楼层
兄弟后处理有问题 要么ijk 要么 xyz  这样的代码  r 不可以的 尽量用ijk 没有为什么
宏程序 G03 i-3 z#1 F3500
发表于 2016-4-12 12:50:26 | 显示全部楼层
还有最基本的平面要清楚    G17 XY IJ G18 XZ IK  G19YZ JK
 楼主| 发表于 2016-5-30 23:04:56 | 显示全部楼层
谢谢,大家。
GMT+8, 2025-2-27 20:16
