catia转换为iges或stp格式用ug打开掉面啊,很无语啊,打开igs文件数据有颜色但是掉面啊,打开stp格式文件数据没有颜色了面有的地方还是缺啊,大虾们帮帮我吧。请问各位大虾,catia能转换出xt格式的文件吗?ug错误提示:打开ug8.5 catia v5的转换器时出现下面的提示:UGII_JAVA_HOME must be defined
The Java Runtime Enviroment (JRE) was not found.
Install your own JRE and set UGII_JAVA_HOME
in D:\Program Files\Siemens\NX 8.5\ugii\ugii_env.dat
to the directory containing the bin and
lib directories.
请按任意键继续. . .
