查看: 4897|回复: 4
[已回复] SolidWorks2019安装失败
发表于 2019-7-31 17:43:38 | 显示全部楼层 |阅读模式
安装到百分之20左右x
安装到百分之20左右x
安装到百分之二十左右显示安装失败的界面,请问有什么解决的办法
爱好者VIP1
发表于 2019-8-7 15:34:01 | 显示全部楼层
论坛下的安装包?确定都按照教程的步骤做了?
爱好者VIP1
发表于 2019-8-7 15:34:17 | 显示全部楼层
爱好者VIP1
发表于 2019-8-7 15:34:45 | 显示全部楼层
748
版主
发表于 2019-8-8 23:58:31 | 显示全部楼层
可参考这个,虽然是英文,也不难理解。
I have finally solved my problem I don't know which part was the key of solution but I'll write all of the things I have done
After failed installations I deleted all of the SW documents stuff from c:\program files, c:\program files(x86), c:\windows c:\documents etc
I deleted its registries in HKEY LOCAL MACHINE-> SOFTWARE AND HKEY CURRENT USER-> SOFTWARE
From Programs and features in the control panel , I have deleted all prereqs of SW. such as Microsoft Visual's all of the versions (basically everything that includes 'microsoft visuals' in their names.), Microsoft SQL server stuff, NET.Frameworks
I have also removed Bonjour (I dont know why but i saw it was suggested in another post which were about a similiar error of mine)
I then downloaded Microsoft's FixIt app and uninstalled some of the Microsoft Visuals stuff that were invisible in Programs and Features Tab.
I have disabled Firewall , Antivirus etc
And this is an extra point : At first because of it being a dll error , i downloaded the floxpress.dll from the internet and manually registered it into System32 and SYSWOW64 if you have done the same thing , also unregister it and delete it from your pc and delete its registries too.
GMT+8, 2025-1-7 11:51
